Gas Fireplace 's flame doesn't spread all areas
Hi
The flame of Gas Fireplace doesn't spread all areas , in spite the lit persists
even after move the knob to on , please advice : below are the steps I have done and the picture explain what issue I have :
1- I turned the Knob on Pilot
2- Keep Press on Pilot at the meanwhile press on the iginition button
3- after the pilot is lit I wait around 1 minute and the pilot remain lit
4- then turn the knob to On
the light is stays lit but the flame doesn't spread in all areas
and May I know the purpose of wall switch ? sorry I am a beginner on this !
I appreciate your help on this matter
Maybe you have to clean out all plugged orifices.
I have found that a Turkey Pin (stainless steel pin used in kitchen for stitching shut the turkey cavity after it's stuffed with dressing) works well for this purpose.
So your description is to get the pilot lit, the wall switch should open the valve to turn on the flame!
The burner needs cleaning every few years, it can get clogged up with dirt and rust!
There are many holes in the burner that must remain clean. All the ones in the front are covered with embers. They need to be clear. I added a red arrow to your picture. That is where the orifice is and the air gets mixed to the gas. That opening in the burner is a perfect home for spiders. It would be best to remove the burner and clean all the holes, vacuum that air chamber and clean the orifice. The orifice will be a tiny hole in a brass fitting. It can be cleaned with a straight pic or a bristle from a wire brush.
If the burner is lighting at all..... the wall switch is ok and working.
