Monessen Thermocouple Removal
Old 10-22-19, 11:13 AM
Don W's Avatar
As the title implies I am having a heck of a time trying to figure out how to remove the thermocouple from the housing that holds the pilot, igniter, thermopile and cthermocouple. I have removed the bottom nut from the original thermocouple and I thought that the unit would just drop out of the housing. It doesn't... Any ideas as to how to remove it?
Hope the link to the pic comes across...
https://lh3.googleusercontent.com/4U...w=w528-h937-no
Old 10-22-19, 12:57 PM
Received 381 Votes on 358 Posts
That link is to a private picture. You'd need to set it to public or you could post it directly to the board.
How-to-insert-pictures.
A model number of the unit you are working on would be helpful too.
Old 10-22-19, 01:10 PM
Received 242 Votes on 221 Posts
I have seen some assemblies where the individual components like the thermopile are not intended to be removed. You replace the whole assembly. I have been able to remove those non-removable ones by bending the metal tabs holding the thermopile in place.
Old 10-22-19, 02:27 PM
Don W's Avatar
Sorry about the bad link. Try this one:
https://photos.app.goo.gl/SyVKmzebJ1wjbhr78
Old 10-22-19, 02:52 PM
A Majestic stove. Looks like a 28D0400 thermocouple. Yours may be welded in there from the heat.
There are some styles that can actually mount in the plate.
Old 10-22-19, 03:35 PM
Don W's Avatar
So ideally I should just be able to pull the thermocouple out from the bottom? Do you think some heat from a torch would un-seat it? It appears that that is the last option I have...
Old 10-22-19, 06:20 PM
A torch may help. You'll probably need to turn the old piece out. It will be damaged in the process.
