Reconditioning steel fireplace
Old 08-23-20, 08:51 PM
N
Received 1 Vote on 1 Post
Thanks for helping out to remove the fixed logs in my fireplace, I removed it all now it's bare and the steel hearth is exposed with rust. Any suggestions on how to recondition everything in the pictures? Is there such thing as high temp rust converter or rust proofing paint? Or should I just stick to high temp black paint?
Also, what's the best way to clean the pilot assembly, thermocouple and all? Thanks again.
Old 08-24-20, 02:18 AM
Marq1's Avatar
Received 365 Votes on 341 Posts
High temp paint, no converter or primer, they will burn off,
Sand it all down with fine 220 gritt paper so you done have any deep scratches!
I need to do mine again, it only lasts a few years between repairs!
ngrome voted this post useful.
Old 08-24-20, 06:26 AM
P
Received 619 Votes on 572 Posts
Before sanding or painting make sure you thoroughly cover all the gas working bits, especially the pilot assembly.
Old 09-12-20, 10:41 AM
N
I noticed the pilot assembly has quite a bit of carbon or soot on it. What do you think about using carburetor or throttle body cleaner, the kind you spray on, like for a car to clean it off, as these parts of a car have similar carbon deposits on them? Or is this a bad idea?
