Superior B-600CMN Troubleshooting
I recently moved into a home with an (I assume) original Superior B-600CMN gas fireplace. It has a wall switch and has been working great for the last six months or so. A few days ago, the wall switch stopped working. I went to the manual and started trouble-shooting.
The pilot is functioning. I confirmed continuity in the wall switch. I confirmed continuity in the limit switch. I checked voltage across the TH TP and TP terminals (i.e. thermopile), and it read 325mV, which was what it was supposed to be. I turned the pilot back on and tried the wall switch, and it worked! For about 30 minutes...
I checked the voltage across the TH TP and TP terminals again, and the voltage kept creeping up, first to 400, then 500, then I de-energized everything not knowing what was going on. Is this sequence of events pointing to something obviously wrong?
Thanks in advance!
Thanks in advance!
Hi, when it shuts off after 30 minutes check to see if the limit switch has opened.
what voltage creeps to 400/500 volts?
Also check to be sure the flame sensor stay engulfed by the pilot flame and is not getting sucked away for some reason.
Geo🇺🇸
Geo🇺🇸
Thanks. I meant to say 400-500 mV, which was the voltage on the thermopile after turning fire off. After some more experimenting, I may have gotten it to work. I adjusted the connections on the limit switch, and it's been running for hours no problem with the voltage hovering between 245 and 270 mV.
Welcome to the forums.
Another thread running back to back..... non-working-superior-fireplace.
Lot of diagrams and pictures. Should be visible again tomorrow.
With a millivolt system..... the safeties, thermostat, power switch and connections must all be in good shape. You're working with under 1v so any loss is a problem.
