How to remove a fireplace insert
Old 01-25-21, 10:19 AM
Received 1 Vote on 1 Post
OK, I have reached this project in my newest home of renovations and I left it for last as I do not know where to begin. How do I remove this fireplace insert? I believe it has been in the house almost since the house was built in 1979.
All advise would be greatly appreciated.
Thank,
Doug
At my house what can go wrong, Does!!
Old 01-25-21, 05:26 PM
Received 1,403 Votes on 1,298 Posts
The picture are good. I see the cord behind the upper corner of the frame so the frame isn't attached to the brick. No visible silicone. Some use a type of clamps while some are held in by just weight.
Does that door open ?
Have you tried sliding it out ?
If there is an access panel in the bottom you may be able to locate a make and model number.
Old 01-25-21, 05:38 PM
P
Received 785 Votes on 722 Posts
All inserts I have seen are just slid into position. You can lay something like a piece of luan or a floor mat on the brick to help protect it against scratching. I open the door so I can get a good grip on the top of the opening to lift & pull.
Old 01-26-21, 08:03 AM
Thank you both for your replies. How heavy do you think this might be? Is it a one person or two person job? I have already removed all the fire brick tiles from the inside.
Thanks,
Doug
Old 01-26-21, 09:53 AM
P
They are several hundred pounds. I can shuffle and move one by myself and pick up a side when it's outside the firebox.
Old 01-31-21, 06:19 AM
Geochurchi's Avatar
Temporarily Suspended
Received 89 Votes on 84 Posts
Hi, could there be a gas line attached ?
Geo🇺🇸
