Blower fan has reduced power
Old 11-16-22, 06:56 AM
The blower on my gas fireplace seems to have reduced power. Itís Running much quieter and has reduced air flow. I grabbed a blower out of a different fireplace and plugged it in and it was the same. My wife and I both noticed the fan was much quieter so not sure whatís going on with it.
Old 11-16-22, 08:52 AM
P
Received 2,108 Upvotes on 1,887 Posts
Is the fan AC or DC powered?
Is it variable speed or do you have a speed control for the fan?
If it's AC would start by plugging the fan into a standard, known good outlet somewhere else in the house. If it runs fast that points to how power is supplied to the fan in your stove/fireplace.
It is probably not an obstruction in the ducting because that would make the fan turn faster.
Old 11-16-22, 09:27 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
I dont think I have ever seen a non variable speed blower on a fireplace!
Old 11-16-22, 10:17 AM
AC powered, will try plugging into other outlet and see what the result is.
If itís variable speed what controls it. Iíve only noticed it running at one speed but I could be missing something.
Wondering if it could be the thermostat?
Old 11-16-22, 10:37 AM
Received 3,891 Upvotes on 3,488 Posts
Possible but doubtful.
Those use snap-disc thermostats that typically work or don't.
That would be one reason to plug the fan into a different receptacle.
Old 11-27-22, 08:41 AM
The blower works fine when plugged in to a different receptacle. Looks like it may have a switch I didnít see initially, will check that next
Old 11-27-22, 10:25 AM
There will be a thermal snap switch something like this in the hot line to the blower.
