So I have a gas fireplace that has been sitting empty since I bought the house 5 years ago. I finally bought a gas fireplace log set and am about to install it. I had questions:
1. The wall that the gas pipe comes out of has a broken piece that has just been propped back in. Is that dangerous? I just have a mental image of flame sneaking into the wall and burning the whole house down
2. The gas pipe has a cap placed at the end. It was very tight and took a lot of effort to remove the cap. While I was struggling it, the whole pipe was shaking and I could hear the pipe creaking in the wall. What are the chances that some joint or connected developed a small leak/crack?
I may sound a bit paranoid but I have never done any work with gas pipelines and/or fireplaces and want to make sure I don't burn the house down.
1. It's generally not an issue though I like to seal any opening around the pipe. I use refractory cement or a similar high temp mortar. As far as flames getting in there it shouldn't. Your logs and the flames will be at least several inches above the opening.
2. Yes, you should be concerned. It is very important that you hold the pipe nipple (the horizontal pipe) securely in place when you remove the cap with another wrench. If you turned the pipe or let it transmit too much torque into the piping in the wall a leak is possible. I'm not saying it's a huge risk but that piping is tightened together and tested. Any movement of the joint, especially loosening, has the potential to cause a leak.
Do you have other gas appliances in the home or is this stove the only thing? If it's the only thing you can disconnect the gas source, connect a test pressure gauge and then pressurize the house's gas piping to 50 psi with air. Write down the temperature. Then 24 hours later check the air pressure and try to do it when the house is the same temperature as when you initially filled the system. Temperature difference can cause the gauge to move but loosing 10% in a day may indicate a leak.
Another option if you are concerned about the gas piping in the wall is to open up the wall. Then, with the system pressurized brush children's bubble soap on all joints and connections. If you see bubbles forming that is a leak.
Hello everyone, i need to install a vent for the gas stove , i can stay on the side of the building without going thrue the roof ,
but i need to find how many ft away from the second floor windows.
Do anyone know where i can find this info ?
Thanks a lot Read More
Hello,
I own a Napoleon GD/CVD36 natural gaz fireplace. I've had it for 15 years and I don't use it often. For the past few years, it has stopped working and I can't figure it out.
Attached if the user manual. I read it carefully, especially page 56 - Troubleshooting.
Here is my situation:
1- The fireplace used to work fine, but for a while now, it will not turn on
2- The pilot works fine and the flame seems to engulf the thermopile with a problem (see attached pictures)
3- There is what seems rust on the pilot burner
4- There used to be a thermostat to control the fireplace. I hated this solution so I jerry-rigged a system to close the "control loop" via my computer for a set amount of time (15 minutes). However, in order to debug the current situation, I disconnecter altogether my system, and instead just shorted the 2 wires where the thermostat used to be. This is the black and white wires with the brown shield. So I basically shorted the botton TH with the top TH screws.
How can I identify the problem that prevents my fireplace from working.
Thanks[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/pxl_20231115_194425564_2947255af825af683a45f47a6f23d5e6231e82cc.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/pxl_20231115_213807676_5ec44d4c3dbffd7da734edda1b6daf1c34036b76.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/pxl_20231115_194638870_31aeb13f6be092a7b730e5b1b5997923c8eb8c57.jpg[/img]Read More
