How long of run can a copper pipe be from a black iron pipe.
Old 05-14-24, 05:42 PM
Z
The fireplace and dryer are split off a 1/2 pipe using copper line to the fireplace which is approximately 15ft long Is this to code or good enough to run both at the same time?
Old 05-15-24, 04:28 AM
B
Received 310 Upvotes on 275 Posts
Confused. Could you provide line diagrams showing current piping and what you want?
Old 05-15-24, 05:06 AM
P
Received 2,236 Upvotes on 1,995 Posts
I assume you are talking about running a gas line?
I do not know of any codes limiting the length of permanently installed gas lines. You do need to properly size your gas line for the length of run.
Old 05-15-24, 12:43 PM
Received 4,059 Upvotes on 3,642 Posts
Average consumption........
A dryer 25k Btu and a gas fireplace can be 30k - 40k Btu...... that's 65k Btu.
Your are on the border.
What did that 1/2" connect to.... something larger ?
Old 05-20-24, 09:18 AM
Z
Straight run
The pipe is basically a straight run. It starts as a 3/4" by the hot water heater then reduces to 1/2". Splits into two smaller copper lines from the 1/2" to the dryer and fireplace. One copper run is 8ft the other 15ft.
Old 05-20-24, 08:02 PM
You have a 3/4" line feeding two 1/2" copper lines.... how ?
A tee at the end of the 3/4" ?
