fireplace
fireplace
We are considering putting a woodstove in the center of a great room, sort of between LR/Dining areas. Is this a good or bad idea? Thanks.
Received 1 Upvote
1 Post
It would heat the room the best from that position.
Just make sure that it has a good fireproof base to sit on.
You can run a zero-clearance (triple-wall) chimney straight up through the roof.
Good Luck!
Mike
Good Luck!
Mike
