What prevents water damage best- ceramic tile floor or linoleum?
Old 03-26-02, 05:09 AM
not_switzerland
Question What prevents water damage best- ceramic tile floor or linoleum?
Old 03-26-02, 05:14 AM
the_tow_guy's Avatar
Received 198 Upvotes on 158 Posts
Well sheet linoleum would be the most waterproof; you could basically build a boat out of it. Only place water could get past would be where it meets the walls. Ceramic is fairly waterproof, too, however if you flooded the floor the water would eventually get down to the subfloor via the grout lines and it the tile is unglazed it would eventually get right thru the tile.
Old 03-26-02, 05:16 AM
And if you're not in switzerland you must be in New Bern, not Bern?
