open a sealed up fireplace?
I have a brick fireplace that has been covered with sheetrock. I would like to remove the sheet rock at the fireplace opening and place an insert inside the opening. My question is do I have to remove all the sheet rock- or just punch a hole at the center and remove the sheet rock until I get to the end of the brick. If the fireplace looks bad can I buy a mantle and cover up the brick? When I bought the house FHA said the fireplace looked perfectly good on the outside.
thanks ......
thanks ......
Opening a sealed fireplace
Contact your local chimney specialist before beginning your project. Any repairs to the chimney is best done by a professional. A professional inspection will help you know what you are up against as far as repairs, relining, and your budget.
