WoodBurning Stove Installation SemiEasy?
I want to isntall a woodburing stove into my living room of a stud on concrete slab house with simple 'rock'walls...and a single tory...is this a doable thing fairly simple or is there major "code' work involved...?
thanks for any suggestions or 'watchout fors'..
rojo
rojo
Installing a woodburning stove
It is recommended that one should always seek the advice of a professional when buying and installing a woodburning stove. Sizing, selection, installation, operation, and maintenance are important considerations. Improper installation could result in a housefire and air pollution. Read and follow manufacturer's instructions. It is also important to check with local authorities regarding building codes and permits. Improperly installed stoves can affect the draft of the stove. Proper draft is important for reducing pollution and to assure your stove works at optimum efficiency.
yes...that is always an option...but this is a DYI site and with the proper information source...i thought there might be a guideline book for something that's been heatin houses hundreds of years...
thanks anyway...
rojo
p.s. i installed a woodburing stove in my sailboat and it was heaven in there for warmth and dryness...
thanks anyway...
rojo
Yes Rohondo,this is a DIY site,however,this particular forum deals with FIREplaces-the members here try to help as best we can with diy projects but stove installations require the utmost thought and safety considerations before installing.Fireplaces and stoves can be dangerous to you and your family when not installed correctly.We can give advice on many subjects here - repairs,cleaning,refacing,etc,however installations are best left to a proffessional.You must also pass clearance codes with your local building inspector.If you do decide to do it yourself without having it inspected,be forewarned that insurance companies will not cover smoke/fire damages caused by faulty stove installations without being passed by town inspectors.
Wood burning stove installation
Thank you for reinforcing the issue of professional inspection and installation. Living in Appalachia, we get many reports every year regarding house fires and wood burning stoves.
