Wood Floor Foundation for Storage Building
Hello...could someone please let me know if there is a link somewhere for a how to w/ diagram for building a plwood covered, wood frame floor/foundation with 24" centers built on concrete blocks for a storage building to set upon.
Thanks,
Ian
Thanks,
Ian
You should use pressure treated wood for the joists/stringers and exterior grade plywood for the floor. I would also use pier blocks instead of concrete block. I like to dig a shallow hole (3"-4") about twice the size of the pier block and puddle a concrete base for the pier.
Also make sure that you;
1. Have at least 8" between any earth and wood,
2. Provide adequate ventilation of the space under the floor,
3. Grade the area to ensure that water doesn't collect under the shed.
There is pressure-treated plywood. It's used to build wooden basements.
http://www.kurmas.com/system1.htm
