stained sub floor
Old 03-25-04, 12:03 PM
kellieparker20
Damaged subfloor
I have damaged sub floor that is visible in the kitchen. How can I repair?
Old 03-25-04, 12:05 PM
kellieparker20
stained sub floor
Some of the sub floor is stained at the front wall where the master bedroom meets the two story portion of the house. How can I repair?
Old 03-26-04, 04:46 PM
I must be confused. Why would you want to fix it. Sub flooring gets covered up with the real floor.
Old 03-26-04, 04:48 PM
Why are you even able to see the sub flooring. It is covered up, or should be by the flooring ?
Old 03-28-04, 05:40 AM
awesomedell's Avatar
I'm with Jack, why is the subfloor exposed?
Old 03-28-04, 05:46 AM
Subfloor is generally plywood, although alot of track homes are now being built using osb for subfloors, this is usually 1 or 2 layers over which goes the finished floor covering, ........tile, hardwood planks, rug (carpet), etc.
I gonna merge your two post in this forum Kelli, as they are kind of the same question & Jack, myself & probably others are still wondering why the concern over the subflooring?
