Trimmers for door in load bearing wall
Old 08-16-04, 07:11 PM
Dan'l
I am inserting a door in a load bearing wall (two-story Cape Cod). The opening between king studs is 45 inches. I've used three 2 x 10 boards plus 1" plywood cut to size for the header.
I planned to use two trimmers on each side, but now wonder if I could use one instead. Local jurisdiction uses 2000 International Building Code.
Any information would be appreciated. Thanks.
Old 08-16-04, 07:38 PM
S&W Constructio
Steve
In most areas I have worked in framing over the years a single trimmer is sufficient in any opening under 60", unless there is an extremely large bearing load over the header in question. In that case I recommend 2 trimmers. Good luck on your project.
Old 08-17-04, 05:04 PM
Its a fairly commom practice, that when supporting door headers 8' and longer, or any header supporting 2nd floor loads, to install doubled full length trimmers.
