creating a passthrough
Old 08-18-04, 12:40 PM
deep6blue
Hello all, I'd like to run an idea here and see if I'm on the right track. We have a one level rancher with an unfinished attic. I would like to create a passthrough between the kitchen and dining room.
An image of the existing framing is here:
http://home.comcast.net/~deep6blue/w...e_original.jpg
Can I do the following without getting into any structural issues:
http://home.comcast.net/~deep6blue/w..._passthrough_1
Or is this a better idea:
http://home.comcast.net/~deep6blue/w...sthrough_2.jpg
This ~might~ be a load bearing wall, but with extra 2x4's in the second picture it should support the wall right? Do you all foresee any issues?
Old 08-18-04, 08:17 PM
This is closer, but not correct.
http://home.comcast.net/~deep6blue/...ssthrough_2.jpg
Cripples above header on each end.
Continue trimmers from sill to sole plate.
If this a nonbaring wall, use a 4x4 HDR.
In single story residential construction, the general rule for determining HDR. size, is that, for each lineal foot of baring wall removed, 1" is added to the HDR. height, IE. 1to4'=4x4, 5'=4x6, etc.(4x5 is not a nominal lumber size).
If there are framing members crossing, joined over, or terminating on this wall, it is baring and you will need to support that load, from both sides, before removing the wall.
