Garage floor with a drain cover
Old 10-04-04, 10:02 AM
bork
Question Garage floor with a drain cover
I would like to turn my garage into a room planning permission pending, I have a concrete floor which has a drain cover in the middle of it, can I get away with a wooden sub-floor and a hatch, or do I have to get it moved
Old 10-04-04, 10:30 AM
Doug Aleshire's Avatar
bork,
I would obtain a neopreme plug for this drain and then procede with your floor using sleepers. I would think this is permmisaable but you should ask your local building authority first. The existing drain should had been noted on drawings.
Hope this helps!
Old 10-05-04, 05:19 AM
bork
Originally Posted by Doug Aleshire
bork,
Hope this helps!
Many thanks
Mark
Old 10-05-04, 05:37 AM
Bork,
You're welcome!
Good Luck!
