floor support
floor support
We're planning a conversion of a second floor bedroom into a master bath. Our current plan is for a separate tub (perhaps mod-sized 1 person soaking tub or air-jet) and separate shower. Planned tub placment is perpendicular to floor joists. Should existing joists be sufficient support? The house was built in mid-70's and current floor is level. Thanks!
As Ed mentioned "check your local codes"... My residential building codes do not call out anything special for a bathroom. They treat all rooms the same.
If you are planning on installing a marble floor, stone shower with heavy glass, granite counters and a large cast iron tub then I would start to look at things more closely. ***All of this assumes that the original construction was proper. If shortcuts were taken originally than who knows what will happen.
Floor support
Do check with local building inspector regarding any structural changes and permits. Building codes and enforcements tend to vary from area to area. It is always best to consult with professionals to protect the investment in your property.
