Garage foundation
Old 11-01-04, 04:10 PM
John Ozier
Garage foundation
I have a 20 x 20 very old garage with wall studs on 24" centers. The 6 x 6 sill is raised off the floor about 4". I want to put in a conventional cement block foundation to close in the space at the bottom. Can I brace a section of the wall, cut the studs and sill, put down the blocks, a new sill on top and nail down the studs to the new sill? If so, what length of wall could I brace and cut out safely while putting down the blocks and new sill plate? I imagine I'll have to go to 16" centers on the studs, but that isn't the problem.
Is this the way to go, or should I just tear down the garage and start over? The studs are old true dimension lumber and in good condition with lap siding on the exterior. Thank you for your advice.
John
Old 11-02-04, 02:34 AM
T
Framing garage
This thread has been moved from Garages to Framing Forming for discussion.
