Cracked Roof Truss
Old 01-04-05, 09:04 PM
Buckeye
Cracked Roof Truss
I am building a new house and the roofing contractor fixed a cracked truss (nearly all the way through), by sistering 2X4's to both sides of the truss. Is this a solid repair or will I have problems when I move into the house?
Old 01-06-05, 06:21 AM
awesomedell's Avatar
Well I would have thought the contractor would have gotten the manufacturer to replace the cracked truss if it arrived that way, but probably a bit late for that now. The repair you described should be fine.
Old 01-10-05, 06:39 AM
I would insist
that the contractor get a sealed drawing from the manufacturer that the repair is done correctly. Most of the time a crack can be repaired in a manor similar to which you decribe. However depending on the forces in the truss the member may not be attached properly. Only the manufacturers plate company can correctly specify the repair. If notihing else do it for liabilty reasons. I think that would give the manufactuer an 'out' in case of a law suit.
Old 02-02-05, 03:56 PM
Wood Truss framing is a pretty redundant. While there is a chance that the repair is not structurally adequate on paper, the chances of it causing you problems is pretty slim.
