Dricor??
rlepore's Avatar
01-06-05, 11:07 AM   #1
rlepore
Dricor??
I'm finishing my basement & have some humidity in the summer time. I would like to lay carpet down & have heard NEVER to lay carpet on concrete. I never heard of Dricor so I'm asking if I should lay this first then carpet??? Can I even lay carpet on this stuff?? & will DRICOR pretty much eliminate my concern about himidity & smell from it???
Joe Carola's Avatar
01-06-05, 04:25 PM   #2
Yers you can use carpet on it. Here's the website. Good Luck.
http://www.dricore.com/en/efaq.htm
Joe Carola
jackspop's Avatar
01-06-05, 04:29 PM   #3
jackspop
I am at the same step you are and have looked into DriCore as well. They are 2' x 2' panels and you can lay carpeting over the top. You will lose about an inch of ceiling height Here in Milwaukee, WI they are about $5 per panel at Home Depot. They say to divide the sq. ft. needed by 3.3 and that will tell you how many panels you need. Here's there website: www.dricore.com. Good Luck.
rlepore's Avatar
01-07-05, 07:39 AM   #4
rlepore
This forum is AWESOME. Thank you Joe & Jackspop. Rocco
