how do you build a foundation for a 2 story..........
i am planing to build a room and another room on top of that, how do you build a foundation that is strong enough to hold this structure? i am turning my back patio into this plan and i will be attaching it to my old house,
i am here in CA. thanks
Hello & welcome to the forums.
This is pretty ambitious project for a diyer to tackle on their own. Also your location being in Ca, you got more stringent building codes & regs to deal with than other areas of the country, especially the midwest where I'm located. In short I would highly recommend that you contact a local reputable contractor to discuss this project and consider letting a pro to the work at least up the point where it's framed up & dried in, then tackle the interior finish work yourself maybe.
Here's a link to the permit place, you can look up code & permit requirements for your project there. http://www.permitplace.com/links/CA.asp
You could post this up in the Concrete forum or the Arch & Codes forums, the pros up there may have some thoughts for you. Good luck.
Received 0 Votes
Mdman,
I've heard similar questions like this asked before about can a one story house foundation accept a second story addition on top. The answer that I give is that a foundation for a one story house is the same as a two sory house whether it's a full basement or a slab in can accept it. I've never seen it as an issue.
So around here whether your building a one story home or a two story home the footings and the rest of the foundation are built the same whether it's a one story or two story unless there's something different in California.
Joe Carola
Joe Carola
Received 0 Votes
Here on the truly left coast, you will find that you will be required to submit a set of plans "wet stamped" by a civil or structural engineer.
The foundation WILL NOT be the same as that of a single story, and will be additionally affected by your areas specific soil condition.
