tool suggestion?
Old 03-30-05, 09:14 AM
mcp
tool suggestion?
I also posted this in the carpentry forum. I'm not sure where it fits best...
Anyway, I want to remove the linoleum and 1/4" underlayment in the kitchen before installing the new floor. Problem is, the toekick is only 2.5 inches tall and 4.5 inches deep. The cabinets are built-in and cannot be moved. So I need to get under the toekick and cut the existing flooring flush with the cabinets.
What can i use to make a close cut in such a small space?
Old 03-31-05, 04:17 AM
Are you sure the underlayment actually goes under the cabinets or does it just run up against the back of the toe kick?
Old 03-31-05, 05:55 AM
mcp
I'm pretty sure it goes underneath. I can doulbe check tonight and say for sure tomorrow (Friday). If it in fact does, do you have a suggestion for cutting it?
Old 03-31-05, 06:57 AM
IBM5081's Avatar
There are at least these 3 options:
An electric die grinder in the long shaft version. HF has these.
A straight grinder (Milwaukee makes one).
A flexible shaft attached to a Foredom powerhead.
All of these will fit into the space described, though you will probably wear out quite a few of the sawblade-on-a-stick cutting wheels.
Old 03-31-05, 12:23 PM
mcp
Both Dremel and Rotozip's have flex attachments. I think I'll give one of those a try, since I can borrow the rotozip.
