Shed Dormer
Old 05-01-05, 05:51 AM
F
Shed Dormer
I am planning a shed dormer addition that will have 2x8 roof rafters. For 3:12 roof pitch and 8 ft ceiling height I will have to cut a 4-1/8 x 16-1/2 bird mouth in the rafters. This leaves about 3-1/2 inches of meat in the rafter to continue the overhang.
Two questions:
1. Does the bird mouth size sound reasonable?
2. Is 3:12 pitch reasonable?
Old 05-01-05, 01:33 PM
Two questions:
1.) NO
2.) Depends upon your snow load.
http://www.awc.org/pdf/WCD1-300.pdf
Old 05-01-05, 03:36 PM
F
I can decreased the roof pitch and reduce the bird mouth to about 7/8 x 3-1/2 (the width of the top plate). Does that seem more reasonable?
It seems to me that snow load would be used to size the rafters and not establish the pitch.
Old 05-02-05, 02:28 AM
F
Hey Snoonyb, thanks for the awc website referral.
I can see clearly now how to do the dormer...by lowering the outside wall I can increase my pitch. Then attach the ceiling joists to the rafters instead of setting them on the wall to keep the 8 feet ceiling height except for a short distance at the outside wall.
Old 05-02-05, 05:10 PM
And as I recall, 2/3 of the area must have a min. 6'8" ceiling height.
Old 05-03-05, 01:00 AM
F
Good point! I will be able to maintain 8 feet except for 3 feet along the outside wall where it tapers to 7'-4. I haven't figured per cent but I am well over code minimums.
Old 05-03-05, 12:45 PM
F
Referring to the awc website:
I noticed that the shed dormer illustration shows the outside wall studs nailed to the sides of the floor joists. I would have expected to see conventional framing with the subfloor extending over a rim joist and a wall with a bottom plate. Although with my remodel project, I would have to either cut off the ends of the existing joists to accommodate a rim joist or fit blocking between the joists.
Is there a reason to frame a shed dormer the way it appears in the illustration?
