Framing about a beam/duct with metal?
hifidigital's Avatar
05-15-05, 07:32 AM   #1
I've gotten pretty good at framing the walls with metal 2x4 and track, but am curious if I can use it to frame around an I beam and hvac ductwork.
Is this possible? If so, what is the proper way to construct it?
Thanks.
Snoonyb's Avatar
05-18-05, 12:43 AM   #2
Use 1 5/8 framed like short walls.
05-24-05, 08:13 PM   #3
What do you mean? Do they make 1 5/8 metal? I've only seen 2x3 and 2x4.
bigmtk's Avatar
VA
05-27-05, 06:21 PM   #4
Yes you can use it, I would use 2x2 metal angle for the corners and 7/8ths metal furring channel(sometimes called hat channel) for the studs.
You will save yourself a few inches of headroom.
Snoonyb's Avatar
