Metal Stud track on concrete floor
Folks,
Is it ok to attach steel stud tracks directly on to concrete or do i need to use treated wood and steel on top
Thanks
Ggops
Thanks
Ggops
For an interior wall not weather-exposed, skip the wood. It's just metal studs and drywall, right?
Will there be any openings in the wall such as doors and cased openings? Those will require more significant attachment.
Originally Posted by ggops
Thanks, Its just metal studs and drywall (non load bearing ) room dividers
The plan is to use wood studs around the door openings.
ggops
ggops
