How to fill holes in subfloor?
We bought a house that the previous owner was in the process of installing a second bathroom. The first bathroom is 5' x 6'. The second is 5' x 5'. I can't figure his reasoning for 2 bathrooms so small, so I'm planning to remove the wall between the rooms and make one 5x11 bathroom. What I need to know is the easiest way to fill the current holes in the subfloor where the 2 toilets and other various holes are.
Received 0 Votes
Cut square holes to the width of the joists, screw 2x4s to either side of the joists inside the hole and screw a piece of plywood down over top of the hole. As long as the holes are not too big, this should be very secure.
