Second Story Bathroom - Cement Floor
onryx2's Avatar
09-22-05, 10:21 AM   #1
onryx2
I am in the process of remodeling my bathroom, which was remodeled in the 60's. When I go to take out the floor, I find the floor is made up the same way the walls were made up of. They used chicken wire with concrete on the floor and then tiled over it. I am replacing the floor. What would be the best way to replace it? Should I tear up all the concrete and then lay plywood, moister barrier and then backerboard? I am not sure how to approach this? Any help will be appreciated.
thezster's Avatar
09-22-05, 10:31 AM   #2
Your "plan" sounds good to me...
I'm not going to ask why you're replacing the floor.... I'm sure you have a reason.... so..... demo to the floor joists... replace with plywood/moisture barrier/CBU/tile (I'm assuming tile, right - otherwise no need for CBU).
onryx2's Avatar
09-22-05, 10:39 AM   #3
onryx2
It is ceramic tile right now and is has a lot of loose tiles. I am also putting in a clawfoot tub in place of the bath and shower surround. It just looks like they clumped cement where ever they could. Yes, I will be laying ceramic tile down. Thanks for the information.
