Plywood over rigid foam
carknocker's Avatar
04-25-06, 02:30 PM   #1
Hi,
My question is whether or not 3/4 plywood layed over 1/2 rigid foam on a concrete floor would be a suitably rigid base for a tile floor.
I know that ideally I should place wood stringers on the concrete with foam in between but finished height is an issue here.
thanks.
em69's Avatar
04-26-06, 10:00 AM   #2
Posted By: carknocker Hi,
thanks.
Any slight movement in the floor would cause the floor to crack. You are better off installing sleepers with the 3/4 ontop and the rigid foam in between the sleepers. There is no issue with height because you could use 1x3s, instead of 2x4s.
