water damage
Old 06-10-06, 06:14 AM
water damage
hello, i removed drywall in my kitchen for a renovation and discovered that some of the framing has some water damage (see this http://brianhava.brinkster.net/home/waterDamage.jpg).
I was going to pull it out and replace it with a new 2 x 4. Is that the correct approach?
I was thinking I'd also caulk the area below the window (the exterior has already been caulked around the window) to try to avoid this in the future.
thanks in advance.
Old 06-10-06, 08:58 AM
airman.1994's Avatar
You should not have to replace unless its real bad!
Old 06-10-06, 12:21 PM
well, that's good news.
is there a rule of thumb i can follow to assess how bad it is?
i think the damage is from a while ago (we've had TONS of rain where i live recently and there doesn't appear to be any new moisture).
it doesn't appear that the wood is too soft either. i was also concerned about any mold that may be there from the moisture. is that reason enough to remove it or is there another way to deal with that?
Old 06-10-06, 08:50 PM
If you see some mold just wipe it down with 50/50 bleach water! If wood is not soft you will be good to go!
