Cutting the top plate - Load Bearing Wall
Old 07-28-06, 11:38 PM
Thanks in advance.
Alright, can I cut the double top plate of a load bearing wall and then bridge it together with a metal strap?
I have removed the soffits in my kitchen and am now seeing that the heating/cooling runs stopped before the top plate, ran into the soffit and then up into the space between the floor joists.
I would like to extend the duct that is in the wall, up past the top plate. This way I will be directly in th space between the floor joist.
I friend stated that I could cut the top plate as long as I bridged it with a thick metal strap.
Old 07-29-06, 01:16 AM
Old 07-29-06, 06:13 AM
I will need to remoe a 8 inch section of top plate between where the joist sit so that I can extend the heat duct upwards. Can I use a strap tie to span that 8 inch section?
Old 07-29-06, 09:55 PM
Minimum, MST 24 ea. side.
