drill 4" hole through rim joist???
In order to install a bath fan in a main floor bathroom with a finished floor above it, is it an acceptable practise to drill a 4" plus hole through a rim joist?? my regular joists appear to measure 7.5"x1.75" so I would assume the rim joist would be the same...
thanks
Matthew
thanks
Matthew
no no
you cant drill a 4 in hole in a 2x8
max would be 1 1/2
why not run between the joist and cut hole in outside wall
max would be 1 1/2
A rim joist is on the outside wall and does not span like an interior joist, except possibly over a small window.
There might be a problem with local terminology.
Dick
Dick
Verdict on the duct holes in a rim joist?
So can you drill larger holes in an exterior facing rim joist to you can run duct thru them?
Followup: what is a good article or website that shows about framing house structures and how loads a taken by various parts of the framing?
THanks all
THanks all
I have done that procedure dozens of times with the blessing of the inspectors. In fact I don't recall it even being mentioned. The way I usually end up doing it without the huge expensive hole saw is to trace the vent fixture and then going a little outside the lines to allow room for the flex ducting, I drill a series of 3/4" holes around the circle with a ship auger bit. Then I connect the dots with a sawzall.
