Floor load in Cedar kit home?
Old 10-27-06, 08:20 PM
H
Hello All,
I can't figure out the online floor load calculators so I found you.
Upstairs I have 2"x6" T&G flooring over 4" x 8" cealing beams on 28" centers, spanning 14 feet. Can you give me a rough idea of this would be enough to support a waterbed? The exposed wood beams have knots and checkering so I guess it's #2 Doug fir. Cal king WB with a 33 sq ft pedestal.
Will I fall through the floor?
Regards,
Hobbitgal
Old 10-27-06, 08:46 PM
T
Received 2 Upvotes on 2 Posts
If it helps, water weighs one pound/pint. Waterbeds can weigh 1800# or more. Weight is distributed over a large area with marketers claiming waterbeds weigh less per square foot than your refrigerator and if house was built to code that it should be able to handle the weight.
Old 10-27-06, 09:23 PM
H
Thanks for the comeback! Well, from what I've seen on the internet, sleeping area live load is 30 lbs per square foot, a cal king (H2O 9 inches deep in a 6' x8' frame) on 33 sq ft of pedestal is 70.5 per sq ft. (Unless I screwed up my math.)
These kit houses are just a bit different, span wise, so I don't know if the waterbed guys are right.
This is a wonderful site, and I look forward to spending more time here.
Thanks!
