Beam span one more try
Old 12-05-06, 06:53 AM
rundog's Avatar
Measure twice, cut once.
could anyone tell me what the span distance is of a triple 2x10 beam? The current one I am looking at, in a basement, is 6 feet from lally to lally and I want to know if i could open this up to an 8 foot span.
thankx
Old 12-05-06, 07:32 AM
D
Consult an engineer. There is more info that plays into the max span of a beam. You need to make sure all loads for that beam are accounted for. For instance it could span 50' with no load on it, but only 5' if you throw mack truck on it.
Old 12-06-06, 05:37 AM
W
Ditto what Danno6102 said.
For REFERENCE ONLY, see below & go to page 27
http://www.ci.watertown.wi.us/Ordinances/Chapter%2013.pdf
