Old Framing Around Stairs Sagging - Help.
maesoph's Avatar
01-15-07, 02:26 PM   #1
Dear All:
I have an 80 year old house that is reasonably sound, but I noticed that the framing around the stairwell is poor and there is some separation and sagging of one side of the joists. It looks to be about 3/4" or so and the plaster on the two floors above is cracked consistant with the sag of the joist. The location is such that a jacking post could be put in without too much trouble, but I need to know the following:
A) If the house is done settling, should I even bother jacking this up?
B) Am I asking for more cracking or other problems is I jack it up?
C) What are the "tricks of the trade" when it comes to jacking?
D) What is the best option??
Thanks in advance
Mike
Wayne Mitchell's Avatar
CT
01-15-07, 03:46 PM   #2
Jacking might get rid of the sag but it won't fix the underlying problem. I think you should probably do a little more investigation before deciding on a repair. Is the sagging joist undersized? Is it separating from a header? Is it one of the perimeter joists around the stairway opening? If so it should be a doubled joist.
Jacking the joist may cause more plaster cracking, but that's pretty easy to fix. The key is to go slowly, making the adjustment over several days.
maesoph's Avatar
01-15-07, 04:33 PM   #3
The joist is properly doubled and all that. It's merely separating from the header - which is improperly doubled. Furthermore, there is no joist hanger - which is probably most of the problem.
maesoph's Avatar
01-15-07, 06:03 PM   #4
It also looks suspiciously like there used to be a bearing wall here, but can't tell for sure.
maesoph's Avatar
01-16-07, 04:40 PM   #5
The post went in today and it easily raised things about 1/4" or so. I will raise it up 1/4" at a time and let you know what happens.. The stairway is headered off extremely poorly - I don't think the problem is anymore than that. I would let it go, but the wall on the first floor above it is a bearing wall.
