Floor Bowed upward by warped joists.
Old 04-04-07, 08:52 PM
Hi folks,
I bought an older house with a newer ~15 year old addition. The floor in the addition is bowed upward in a couple of places. It's pretty noticable. I've identified a couple of joists that are twisted pretty badly and that are pushing the plywood subfloor and top flooring upward. One end of the joist is slipped into a joist hanger the other end is resting on the sill. The joists are 16" OC. There seems to be a bead of adhesive between the joist and the plywood deck. I've done a good amount of home repair in my time so I'm ready for almost anything. These bowed sections don't seem to be load bearing - there's open floor above. Can I just cut out the old joist and replace it? If so what is the best way to flatten the floor above. Weight? Or should I crank it down with allthread and 4x4 cross beams.
Thank you in advance.
Timmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
Old 04-05-07, 03:44 AM
chandler's Avatar
Tim: Welcome to the forums! It may be difficult to do, but could you post a couple of pictures on a site such as photobucket.com, and give us the url, so we can see what you see. It may help in us giving you sound advice.
Trackbacks are On
Pingbacks are On
Refbacks are On
