Squaring-up an existing wall
gollywally's Avatar
05-22-07, 04:49 AM   #1
I am remodeling my kitchen. One wall (10'-6" l) is "out of square" I have layed out a chalk line with a framing square and chalk line , but am not to confident about results any help is appreciated. GW
aq_guy's Avatar
OK
05-22-07, 07:44 AM   #2
Not sure what you are looking at, but...
The most reliable way to square up anything of substantial size, like a wall, is to measure the distance diagonally from opposite corners. When the two measurements are the same, the wall [or whatever] is laid out square.
Once the framing is square, the sheet material [plywood, OSB] is nailed down. This prevents the wall from racking out of square.
This method eliminates the problem of having to tell "by eye" how accurately a right angle corner is laid out.
Wirepuller38's Avatar
TN
05-22-07, 09:32 AM   #3
Square Corner
You can lay out a right triangle of 3-4-5 feet per side or 6-8-10 feet. This is another method of checking for a square corner in a room. Hope this helps. Good luck with your project.
gollywally's Avatar
05-24-07, 02:12 AM   #4
Thanks for your help. I finally had to re-sheet rock the wall to get it square-up, a lot of work but it will fit now. Thanks again. GW
