Sagging floor - add support?
emies's Avatar
MA
06-04-07, 02:04 PM   #1
First of all sorry, if this post is not in the right place.
I'm thinking about buying a house biult (wrong obviously) in 1940. The floors in th emiddle of the house are sagging - upon inspection of the basement we find there are temporary supports (5 of them) placed throughout the basement - apperently they were none or they rotted or something...
In any case, we love everythign selse about the house and am wondering what the code (for MA) for such a thing is and how much effort it is going to be to get the new support beams in. I assume I need to jack the floor up, poor a footting (can I do that on an existing cement floor?) add the steel pole's I have seen in so many basements and I'm good - right? It sounds waaaay to easy!
Will I ever get the floor to be level again? If not, once I get the proper supports under it can I just poor floor leveler/quick level on the floor and tile, carpet, etc.?
chandler's Avatar
GA
06-06-07, 04:50 AM   #2
You will need to check with the local building code department to see if the use of adjustable lally columns is permissible or not. In Massachusetts, they may require you to dig 3' deep footings, pour them, and install concrete block piers. Not sure. If they say using the lally columns is OK, then all you will have to deal with is the footing, which a concrete floor may not give enough support.
