Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Framing, Flooring and Sub-Flooring
Reload this Page >
Load carrying capacity of 2X4 Framing of Attic Floor
Old 06-06-07, 10:04 PM
The question of the load carrying capacity of the framing on a project I am working on came up in my post to a different forum.
I am working on a 1910 era Craftsman style house. I am cleaning the attic, eliminating the knob and tube electric and re-insulating.
I would like to have dead storage up there (you really can’t stand – max head room is probably 5 feet under the peak) and was thinking of adding ¾ inch plywood screwed to the 2X4 joists.
The joist construction is 2X4 with 16 inch spacing and lath and plaster on the underside. The longest run between a load carrying wall is probably 10/11 feet.
From a practical point of view can the structure withstand the weight of the plywood and storage? What would be the live/dead load limits? Are there some simple solution that could be designed that would strengthen the assembly without compromising the space?
Thanks,
David
Old 06-07-07, 01:31 PM
What are the live/dead load limits on a 2x4 joist structure? -
2x4 on 16" centers, asuming E = 1.2x10^6 (SPF of today), 10'3" span, L/240 deflection, allowable loading = 10 psf live/5psf dead load. In other words, you can't (or shouldn't) use it this way for storage.
2x6's alone would up this to over 20 psflive/10 psf dead. My suggestion - sister 10' 2x6's to the existing 2x4's with an air nailer, this would up the capacity even more.
