Glue for subfloor ?
Glue for subfloor ?
What kind of glue has to be used when putting plywood T&G subfloor to the joist and I'm going to use screw to attach the subfloor to the joist , is there any consideration , recomendation about size of the screw , the subfloor is 3/4" , wood I joist 12" deep .
Thank You .
Thank You .
Use a general purpose construction adhesive, some brands explain right on the tube what they are intended for. A polyurethane based adhesive is a step up from the general purpose adhesive. 2" screws should be fine.
Previous Thread
Next Thread
