Under Engineered Hardwood Flooring
Old 07-30-07, 02:00 PM
I want to install engineered maple hardwood flooring over 5/8" OSB. It'll be floating and glued to each other. Do I need any sort of vapor barrier if installed above ground level. The dealer has told me I will only need 1/4" foam underpadding to minimize movement.
Any comments?
Thanks!
Old 07-30-07, 04:16 PM
chandler's Avatar
Yeah, the foam pad the manufacturer sells and recommends will work fine, and will keep you within any warranty that comes with the flooring.
