Advice needed on floor bounce
Old 09-28-07, 09:14 AM
Hi folks,
I have a split level house. The main floor is a great room with a kitchen. When I walk through certain areas of the great room, I get a pretty significant bounce. I finally poked my head into the crawlspace under the great room yesterday -- to find the joists were between 3-4 feet apart from one another, with concrete piers holding the floor up.
What's the best way for a flooring novice to decrease the bounce in this situation. I had read about sistering, but that doesn't seem like it would be sufficient with such a large gap between the joists. I'm not terribly excited about the idea of pouring a few new piers and adding joists, but if that's the best option I will do it. Would running a 2x10 or 2x12 between the joists using hangers help reduce the bounce?
Thanks in advance,
Brennan
Old 09-28-07, 06:54 PM
Your floor joists should be 24" apart at the maximum. I build mine 16" on center as a rule, and many are 12" on center. All of my floor joists are 2x12's.
Old 09-28-07, 07:02 PM
I would definitely add more structure under there.
