Shower Stall Floor
thedelman's Avatar
11-03-07, 07:40 PM   #1
Shower Stall Floor
I hope I have this post in the right place.
I am tiling my shower walls and intend to use a prefabed acrylic shower floor. The stall is 36x36 and the sub-floor is OSB and pretty stable; however, I am thinking if I place a piece of concrete backerboard under the shower base it would provide more support. Thoughts please on whether you think this is necessary.
Thanks so much.
cwbuff's Avatar
CT
11-04-07, 10:17 AM   #2
Backerboard won't provide a much (if any) additional strength. If all you have is a 1/2' OSB subfloor you'll probably get some flexing. Adding 3/4" plywood on top will help provide support, but you'll also have to add some framing to nail it off. Bed the shower base in mortar to keep it from flexing.
thedelman's Avatar
11-05-07, 07:22 AM   #3
Thanks, bedding it in mortar seems to be the best way.
