using shingles to flatten subfloor
Old 01-16-08, 05:55 AM
When you use shingles to flatten an area of the subfloor to get it ready for laminate, how to you fasten it to the floor? Just a simple nail in, or should you screw it in?
Also, do you just lay the underlayment right on top of the shingles, or do you put something over the shingles before you put down the underlayment?
Thanks
Old 01-16-08, 08:42 AM
Gunguy45's Avatar
Super Moderator
shingles?
to build up a subfloor? Wow, thats one I never heard of before. Can't wait for some replies on this.
Sorry, never heard of it before. Always used floor leveling compound.
Old 01-16-08, 09:39 AM
If you do a search in the flooring section for "shingles" you find a bunch of posts. Unfortunately, none of those posts (from what I can find) tells you HOW to do it, only that you can use shingles.
Old 01-16-08, 10:06 AM
Gunguy45's Avatar
Super Moderator
shingles
whitenack,
Ahhh now i see. Like i said, i never heard of it, but then, the only flooring work I've ever done was either over concrete, or steel/aluminum subfloor.
I did see one post about putting the roofing felt as the final top layer, but nothing about how to fasten down when yer using laminate (floating I presume?). They were all talking about naildown.
I'm sure you'll be getting a response soon.
Best of Luckl
Old 01-18-08, 11:10 AM
Here's a stupid thought?
Would just an extra layer of underlayment do the job?
THat might be too thick, but I might be able to whittle some off to make it the correct thickness?
WOuld that work, or would that not be stiff enough?
