Want to relocate telepost.
waramp's Avatar
02-17-08, 01:26 PM   #1
House is a rectangle. There is a supporting wall upstairs down the center of house. A wooden beam - (3) 2x6s. With 5 evenly spaced teleposts on top of concrete pads downstairs.
Im pouring a new basement floor, and want to add a telepost, in order to shift an existing telepost over 2 feet. I want to move it in order to have french doors in the middle of a rooms wall.
X = 7 or so feet. (The space between all the teleposts.)
Heres a picture of:
Upstairs floor plan
Downstairs future floor plan
Downstairs future floor plan + added telepost and relocated existing telepost.
Is there anything wrong with this setup?
Concretemasonry's Avatar
MN
02-17-08, 02:09 PM   #2
Make sure you have a good footing (24x24x8?) under the new posts before you pour the slab over them.
If you are not getting a permit and the free inspection that goes with it, you can be on thin ice!
Dick
i am carpenter's Avatar
PA
03-25-08, 06:09 PM   #3
I imagine you are speaking of an older home? Run flat plate steel the distance/sister to help. If there is a joint above the column, yuck. Pin steel on both side. 2 feet shouldn't matter but I can not see what you see. Post pictures. It really helps. Cheers
