quick question on non-load bearing wall framing...
Received 0 Votes
Since I don't have any 16 foot 2x4's, does anyone know if its generally accepted to build a 15 foot non-load bearing wall in 2 sections and nail them together? Or does it vary from state to state?
I tried serching the forum but found nothing...
thanks for any replies!
Received 0 Votes
What I mean is, if I have a 16 foot long wall to build, is it correct to build 2 8' walls, stand them up, and nail them together?
..and by your reply it looks like I can
Received 0 Votes
That's what I'm saying...
In an existing structure, it's often a very tight fit to try to build a wall then stand it up. If you can do it - great! I usually set my top and bottom plates then nail my vertical wall studs to them.
Received 0 Votes
Are you talking about a 16' high wall or a 16' long wall?
If it's 16' long, then I would stagger the joints on the plates (on the top and bottom).
If it's a 16' high wall that is not load bearing then I don't think there will be much in the way of regulations. But I would be concerned with the wall buckling if you build an 8' wall on top of another 8' wall. If something or someone fell into the wall then it might buckle in the middle. What are you covering it with drywall? You could always throw some plywood on the wall to tie the 2 sections together a little better.
