Uneven cement floor, need advice.
Old 08-09-08, 05:49 PM
Hi,
I am renovating my bathroom and ran into a bit of a snag when it came to removing the old tiles.
I found that the these tiles were installed directly on top of a (wet) cement slab. The problem is that when I started removing these tiles, I notice that some of the cement chips away with the tiles.
So, once all the tiles are removed, I will be left with a slab of cement with many chips and dents and really uneven.
Anybody has any advice for smoothing-out this cement slab before I install new tiles?
I heard of cement-self levelers. Could this help me?
Actually, I found that this cement slab was poured over a really nice hardwood floor (what a sin...). The layers making up the floor are:
- hardwood
- criss-crossing metal mesh
- cement
- tiles
Would it be hard to remove this cement altogether and keep the original floors? probably not.
Thanks for your help!
Old 08-09-08, 07:27 PM
Temporarily Suspended
Removing cement like that is lot of work not to mention $300 for carting. If you really want a wood floor you could install plywood on top of the cement and a wood floor on top of that as long as the height wouldn't cause a problem.
Old 08-10-08, 05:01 AM
thanks.
What is carting?
What about leveling the cement slab after removing the tiles? Does anybody know what I should use for that?
tx
Old 08-10-08, 05:15 AM
Carting is hauling the old cement to the dump.
A mortar mix may work for leveling the existing cement if you don't want to remove it.
