Repairing stud with too large a hole bored
Old 10-10-08, 10:55 AM
I have a 2x4 stud in a non load-bearing wall that has a 2" hole bored through it. (I didn't pay close attention to a helper when I asked him to bore the hole....wrong bit!). I'd rather not replace the stud, because I already have two pex pipes and a pvc drain pipe running through the wall (lower, correct-sized holes).
Is there a way to repair the stud so it will pass framing inspection? I was thinking about sistering 2x4's to either side, but they can't reach the floor (because of the other pipes). Is this sufficient/acceptable, or is there another way to do it without replacing the entire stud.
I have a sketch, but no idea how to upload it.
Thanks.
Old 10-10-08, 04:42 PM
chandler's Avatar
You could either sister a 2x4 against it or cut a piece of 1/2" plywood 3 1/2" wide and a couple of feet long and screw it to the side of the stud. In fact you could screw one on each side to hide the hole.
Old 10-11-08, 05:37 PM
Thank you! I was hoping I could get away with doing that, since it doesn't support anything, but I wasn't sure if there was some framing code rule that prohibited it.
Old 10-11-08, 06:41 PM
nap's Avatar
nap
nap is offline
New Member
there are also framing braces that nail onto each side of the stud. They make them that are even rated for a structural load.
go here:
http://www.tamlyn.com/index_files/PlatesandBrackets.htm
and scroll down to stud braces.
Old 10-12-08, 06:30 AM
XSleeper's Avatar
I think your framing inspector will want to see the stud braces that Nap mentioned. If you want to do the plywood too, that's up to you, but I bet he'd still flag it if you just did the plywood w/ no braces.
Old 10-14-08, 05:12 AM
Thanks! That's great. I have to put plates over a couple of areas where the top plate was cut, so those braces are perfect for both. Thank you for the link.
