Hole is subfloor...
Old 11-01-08, 06:49 AM
Hole is subfloor...
I have a hole in my subfloor in between two joists. What is the easiest way to fix it if it is in a high traffic area?
Old 11-01-08, 07:38 AM
Welcome to the forums!
It would be best if you can add additional 2xs [to the floor joists] to support the patch piece of plywood. You might cut the hole out a little larger to make this easier.
If that's not feasable, you could insert a longer 2x thru the hole and screw it to the sub floor on each side of the hole and then attach your patch piece to it.
Old 11-01-08, 05:22 PM
Or cut back to the center of both joists( might as well cause few holes in subfloors are a nice square patch). Make sure to support between joists, either with a 2x or with the plywood used to patch( you probably will have some left over)and screws on 6" spacing or better.
Old 11-01-08, 06:12 PM
sorry for the hijack, clawfirst check your pm.
Trackbacks are On
Pingbacks are On
Refbacks are On
