Concrete/cement foundation/floor sweating?
Hi,
Your room is slab on grade construction, that is, a concrete slab floor that is always going to be cool as a result of the ambient(ground)temperatures. If moisture is present it will codensate on the floor. If you had a wood framed floor with a crawl space you wouldn't have this situation. You live in a very humid locale. Even so, there should not be this much moisture in the room. I'm inclined to think that there is some kind of a construction flaw that is causing this structure to hold moisture such as ventilation, insulation, etc. My advice and the dumb way to remedy this situation would be to buy a dehumidifier. You rent this place. You don't want to spend your money to fix your landlords house and when you leave you can take your dehumidifier with you.
